    Whether you're a seasoned grilling pro or just an amateur griller, having a food thermometer is quite important for getting your cooking just right. It helps you find the perfect temperature for grilling, broiling, roasting, or smoking meats, saving you from a lot of BBQ mishaps.
    We reviewed more than 20 meat thermometers looking at their accuracy, features, and how easy they are to use. In each category, we picked the top ones to make it easier for you to select the best thermometer for perfect meat cooking.
    Most Advanced INT-14-BW
    Probe: 4
    Temperature Range: 14~212℉
    Maximum Ambient Temperature: 572℉
    Probe Dishwasher-Safe: Yes
    Connection Methods: WiFi, Bluetooth, Local Base
    Most Advanced Meat Thermometer
    If you’re after top-notch precision and functionality, then INT-14-BW is the go-to meat thermometer, which unprecedentedly combines three modes of operation - WiFi, Bluetooth and Local mode. With four wireless food-grade stainless steel probes, you can monitor multiple foods simultaneously, with each probe lasting up to 25 hours on a full charge. In addition, it comes with handy preset menus, IP67 waterproof and dishwasher-safe capability, making it the best overall meat thermometer for grilling, smoking and BBQ.
    Read detailed review: INKBIRD INT-14-BW Wireless Meat Thermometer Review
    What We Like
    What We Don’t Like
    • Multiple monitoring modes
    • 4 probes with true-wireless design
    • Dual temperature sensors in 1 probe
    • 29 preset meat menus
    • Dishwasher-safe
    • 25 minutes to fully charge and 25 hours of continuous use
    • The price is relatively high
    Best with Bluetooth Connectivity - INT-11P-B
    Probe: 1
    Connection Methods: Bluetooth 5.1
    Best Bluetooth Grill Thermometer
    INT-11P-B is a wireless Bluetooth grilling thermometer that delivers precise temperature readings from up to 300 feet away. The companion app comes with 26 preset USDA- recommended meat menus, customizable taste preferences, and multiple alarms for temperature and timing, making it easy-to-use from beginners to pros. Similar to the INT-14-BW, this thermometer also features dual sensors in one probe to track both food temperature and ambient conditions at the same time. Plus, it is constructed from food-grade stainless steel with a zirconia ceramic handle for added durability.
    What We Like
    What We Don’t Like
    • True-wireless convenience
    • 26 preset meat menus
    • Durable and waterproof probe
    • Rapid charging and long battery life
    • Dependence on Bluetooth connection
    Best Budget - IDT-22-B
    Probe: 2
    Temperature Range: 32~572℉
    Waterproof: No
    Connection Methods: Bluetooth 5.4
    Best Budget Meat Thermometer
    IDT-22-B utilizes the latest Bluetooth 5.4 technology featuring low latency, anti-interference, and low power consumption, with a transmission range of up to 330 feet. It measures temperatures accurately within 1.8℉ across a short range of 32 to 572℉ and continuously monitors from 32 to 482℉. This meat thermometer has a high-resolution LCD screen with adjustable backlight for clear visibility in any lighting, and a built-in battery life that lasts up to 45 hours for long cooking sessions. What’s more, the app also pre-programmed 29 meat menus to simplify your cooking process.
    What We Like
    What We Don’t Like
    • Bluetooth 5.4 for more stable connection
    • Very reasonable price
    • Extensive temperature measurement range from 32 to 572℉
    • 45 hours of continuous use in low power mode
    • 2 hours of offline temperature data storage
    • Probes are not waterproof
    Best Smoker Fan Kit - ISC-027BW
    Probe: 4
    Waterproof: No
    Best Meat Thermometer for Smoking
    ISC-0027BW is specially designed for smoking, and is compatible with various types of grills such as Big Green Egg, Kamado Joe, Primo, Vision Grill, Akorn Kamado. Unlike regular meat thermometers, this kit comes with a fan controller that automatically manages the airflow based on the grill temperature and grill lid status, making it both accurate and convenient. Powered by a 5V USB power supply, the device is also compatible with mobile power supplies for outdoor grilling. ISC-027BW has four food-grade stainless steel probes with a measurement accuracy of ±0.9℉, and can measure temperatures up to 572℉.
    What We Like
    What We Don’t Like
    • WiFi and Bluetooth dual connectivity options
    • USB power supply, compatible with power banks
    • Historical temperature data and fan output graphs on the app
    • Intelligent grill management
    • High-precision probes with wide temperature measurement range
    • Not so practical for those who don’t have a grill
    Best Instant-Read Meat Thermometer - IHT-1M
    Probe: 1
    Probe Temperature Range: -58~572℉
    Infrared Temperature Range: -58~482℉
    Waterproof: No
    If you’re an experienced cook or just need a meat thermometer with the most basic function, then the IHT-1M is a great pick, which combines the functions of a meat thermometer, a non-contact infrared thermometer, and a cooking timer, for just an extra $3. Although it cannot connect to the app via Bluetooth and WiFi, it has preset menus for 5 different meats and 5 levels of doneness. Plus, the cooking timer and temperature alarm will help you avoid overcooking or undercooking. You can easily check the temperature and set cooking preferences on the LCD screen.
    What We Like
    What We Don’t Like
    • 3-in-1 functionality
    • Instant reading with high accuracy of ±1.0℉
    • Wide temperature range of -58~572°F and calibration function
    • Automatic sleep and wake-up function for energy efficiency
    • Lack the ability of remote monitoring
    Conclusion
    Choosing the best meat thermometer can really change your grilling, smoking, and BBQ game. Whether you’re looking for the most advanced technology on food thermometers, Bluetooth connectivity, instant-read capabilities, budget options, or specific smoker kits, here’s definitely a thermometer that fits your style. Invest in one of these devices to impress your friends and family with perfectly cooked dishes.
