Temperature controller is a hot-selling product of INKBIRD. It has been more than 10 years since it was launched and continuously updated. From a single model at the beginning, to now there are specially produced models according to different usage scenarios and purposes. This may make you confused when buying, but I believe that after reading this article, you will clearly know which one is right for you.
ITC-308 Series
ITC-308 is our classic model, which is fully functional and widely used, covering almost all common usage scenarios. It has dual-stage output, can control refrigeration and heating equipment at the same time, and the device also has compressor delay protection, which can help extend the life of refrigeration equipment. It supports temperature calibration and setting temperature alarm. If the usage scenario is home brewing, planting, hatching or breeding, then this ITC-308 can definitely meet your needs.
There are two versions in the series, the difference is whether it can be connected via WiFi. You can choose according to your needs.
ITC-308S
The functions and parameters of ITC-308S and ITC-308 are the same, the only difference is that the probe of ITC-308S can be directly disassembled and replaced, while ITC-308 cannot. Considering that many scenes where the probe is placed are quite harsh, the probe is easily damaged and may cause inaccurate readings, so many users will need to replace the probe. In order to make it easier to replace the probe, we have improved ITC-308 and changed the connection between the probe and the body to a detachable type.
If your usage scenario is also relatively severe and there is a possibility of frequent replacement of probes, ITC-308S will be more suitable for you.
ITC-306T Series
ITC-306T is a controller that only supports controlling heating devices. The controller is also equipped with two sockets, which can control 2 heating devices at the same time. For some usage scenarios, such as aquariums or terrariums, it may not be necessary to connect a refrigeration device, so using ITC-306T may be a better idea.
This series also has a WiFi-controlled version, you can choose according to your needs.
Aquarium Temperature Controller Series
If you need to place the probe in a humid environment or directly into water, please consider purchasing this series of controllers. All controllers in this series are equipped with aquarium probes, which are very suitable for humid and submerged environments. You can choose different bodies according to the functions you need, including ITC-308, ITC-308S and ITC-306T. Among them, ITC-306A is equipped with dual aquarium probes, and the functions and parameters are almost the same as 306T.
This chapter ends, please read the next chapter.
